Clearing codes
Postby velj » Tue Jul 31, 2012 11:50 pm
Sorry guys on tapatalk don't really no where to post this but il do it here, how do I clear my 30.000km service warning for my 2010 ve sv6 i wasn't paying 387 bucks for a oil change so I am going to do it my self just need to no how to clear the code does my head in on start up any help would be great thanks
velj
Postby ZerOne » Wed Aug 01, 2012 7:36 am
The displayed service reminder is reset using the following procedure:
1) Turn the ignition to the OFF position.
2) Press and hold the TRIP button on the steering wheel.
3) Turn the ignition to the ON position, do not start the engine.
4) Release the TRIP button on the steering wheel.
Important : A confirmation beep will sound upon reset.
5) Once in the Service Reset screen, press and hold the ENTER switch (The LHS steering wheel scroll wheel) for 3-5 seconds.
If the service reminder comes back on when you start the vehicle, the Service Reminder Display has not reset. Repeat the above procedure.
Good work on changing the oil yourself. A lot of the corner mechanics just end up sticking some generic grade oil such as 20w50, or 15w40 in there without really checking the specs as to what the car needs.
There is a bit of info here as to how to reset the service reminder, as well as the oil life reading.
doc-holden-commodore-ve-oil-change-information-d47m19.html#9
Hope this helps
Cheers matti
Postby velj » Wed Aug 01, 2012 8:45 pm
Thanks mate
Yeh changing oil isn't rocket science haha thought id give it a go haha
velj
Postby velj » Tue Aug 28, 2012 1:56 pm
Can't get the oil to reset on the screen :(
velj
Postby ZerOne » Tue Aug 28, 2012 2:49 pm
I take it your talking about the cluster warnings ?
Which one are you having trouble with, the service reminder, or the Oil Life percentage ?
Postby velj » Tue Aug 28, 2012 4:12 pm
Oil life one, iv cleared the service but can't get the oil life one to reset.
velj
