L36 Series OHV V6 (3.8L)
L36 Specifications
Discuss the 3.8 Litre OHV V6 Engine from GM
Postby ZerOne » Fri Nov 19, 2010 9:35 am
L36 V6 Engine Specifications
Type: 3.8L V6 L36
Displacement: 3791cc
Compression Ratio: 9.4:1
Valve Configuration: Overhead Valves
Assembly Site: Flint, MI
Valve Lifters: Hydraulic Roller
Firing Order: 1 - 6 - 5 - 4 - 3 - 2
Bore x Stroke: 96.52 x 86.36mm
Horsepower: 200 @ 5200 rpm
Torque (lb-ft): 225 @ 4000 rpm
Fuel Shut Off: 6000 rpm
Emissions Controls:
Evaporative System
Catalytic Converter
Exhaust Gas Recirculation
MATERIALS
Block: Cast Iron
Cylinder Head: Cast Iron
Intake Manifold:
Cast Aluminum Lower
Composite Upper (C,H,W)
Cast Aluminum Upper (F)
Exhaust Manifold:
High Silicon Molybdenum
Cast Nodular Iron (F, left W)
Cast Nodular Iron (Left-C, H)
Tubular Stainless Steel (Right-C, H, W)
Main Bearing Caps: Powder Metal
Crankshaft: Cast Iron
Camshaft: Steel
Connecting Rods: Cast Iron
Additional Features:
Extended Life Spark Plugs
Extended Life Coolant
Oil Level Sensor
Engine Oil Life Monitoring
Return to L36 Series OHV V6 (3.8L)
