LD9 2.4 Litre DOHC 4 Cylinder Powerplant
LD9 Specifications
Discuss the 2.4 Litre DOHC Inline 4 Cylinder Engine from GM
Postby ZerOne » Fri Nov 19, 2010 10:01 am
LD9 Engine Specifications
Type: 2.4L L4 LD9
Displacement: 2392cc
Compression Ratio: 9.7:1
Valve Configuration: Dual Overhead Camshafts
Assembly Site: Lansing, MI
Valve Lifters: Direct Acting Hydraulic
Firing Order: 1 - 3 - 4 - 2
Bore x Stroke: 90.00 x 94.00mm
Fuel System: Sequential Fuel Injection
Horsepower: 150@5600 rpm
Torque (lb-ft): 155@4400 rpm
Fuel Shut Off: 6500 rpm
Emissions Controls:
Evaporative System
Catalytic Converter
MATERIALS
Block: Cast Iron
Cylinder Head: Cast Aluminum
Intake Manifold: Composite
Exhaust Manifold:
High Silicon Molybdenum Cast Nodular Iron
Main Bearing Caps:
Cast Nodular Iron
Crankshaft: Cast Nodular Iron
Camshaft: Cast Iron
Additional Features:
Extended Life Spark Plugs
Extended Life Coolant
Return to LD9 2.4 Litre DOHC 4 Cylinder Powerplant
