LE9 2.4 Litre VVT Ecotech E85 4 Cylinder Powerplant
LE9 Specifications
Discuss the 2.4 Litre VVT Ecotech E85 (Flex Fuel) Inline 4 Cylinder Engine from GM
Postby ZerOne » Wed Nov 24, 2010 7:40 am
2010 Ecotec 2.4L I-4 VVT ( LE9 ) 06/05/2009
Type: Ecotec 2.4L I-4
Displacement: 2384 cc (145 ci)
Engine Orientation: Longitudinal or Transverse
Compression ratio: 10.4:1
valves per cylinder: 4
Assembly site: Spring Hill, Tenn.
Valve lifters: Hydraulic roller finger follower
Firing order: 1 - 3 - 4 - 2
Bore x stroke: 88.00 x 98.00mm
Fuel Type: Regular unleaded, E85 Flex Fuel ( Chevrolet HHR and Malibu )
Chevrolet HHR 172 hp ( 128 kW ) @ 5800 rpm SAE CERTIFIED ( gasoline, as tested )
176 hp ( 131 kW ) @ 5800 rpm SAE CERTIFIED ( E85 Flex Fuel, as tested )
Chevrolet Malibu 170 hp ( 127 kW ) @ 6200 rpm SAE CERTIFIED ( gasoline, as tested )
175 hp ( 130 kW ) @ 6300 rpm SAE CERTIFIED ( E85 Flex Fuel, as tested )
Chevrolet HHR 167 lb-ft ( 226 Nm ) @ 4500 rpm SAE CERTIFIED ( gasoline, as tested )
170 lb-ft ( 230 Nm ) @ 5000 rpm SAE CERTIFIED ( E85 Flex Fuel, as tested )
Chevrolet Malibu 158 lb-ft ( 214 Nm ) @ 5200 rpm SAE CERTIFIED ( gasoline, as tested )
170 lb-ft ( 230 Nm ) @ 4700 rpm SAE CERTIFIED ( E85 Flex Fuel, as tested )
Maximum Engine Speed: 6750 rpm ( forward gears )
Emissions controls:
Evaporative system
Catalytic converter
MATERIALS
Block: Cast aluminum
Cylinder head: Cast aluminum
Intake manifold: Composite
Exhaust manifold: High silicon molybdenum, cast nodular iron
Main bearing caps: Aluminum bedplate
Crankshaft: Cast nodular iron
Camshaft: Cast nodular iron
Connecting rods: Forged steel
Additional features:
Extended life spark plugs
E85 Flex Fuel
Extended life coolant
Electronic throttle control
Variable valve timing
Dual converter system
Return to LE9 2.4 Litre VVT Ecotech E85 4 Cylinder Powerplant
