2010 GM 3.5L V-6 VVT ( LZE ) 06/05/2009
Description: 3.5L V-6 ( LZE )
Type: V-6
Displacement: 3510cc (214 ci)
Engine orientation: L=Longitudinal T=Transverse T
Compression ratio: 9.8:1
Valve configuration: Overhead valves
Valves per cylinder: 2
Assembly site:
Tonawanda, NY
Ramos Arizpe, Mexico
Valve lifters: Hydraulic roller
Firing order: 1 - 2 - 3 - 4 - 5 - 6
Bore x stroke: 99 x 76 mm ( 3.90 x 3.00 in. )
Bore Center (mm)
Bore Area: (cm2)
Fuel Type: Regular unleaded and E85 Flex Fuel Capable
Maximum Engine Speed: 6400 RPM
Emissions Summary:
Catalytic converter
Evaporative system
Chevrolet Impala 211 hp ( 157 kW ) @ 5800 rpm SAE CERTIFIED
Chevrolet Malibu 221 hp ( 165 kW ) @ 5800 rpm SAE CERTIFIED
Applications: Torque: lb-ft ( Nm )
Chevrolet Impala 216 lb-ft. ( 293 Nm ) @ 4000 rpm SAE CERTIFIED
Chevrolet Malibu 221 lb-ft. ( 300 Nm ) @ 4000 rpm SAE CERTIFIED
MATERIALS
Block: Cast iron
Cylinder head: Aluminum
Intake manifold: Cast aluminum
Exhaust manifold: High Silicon Molybdenum
Main bearing caps: Powder metal ( 1,2,3 ) cast iron ( 4 )
Crankshaft: Steel
Camshaft: Assembled steel
Connecting rods: Forged powder metal
Additional features:
58X Crankshaft
Variable valve timing (VVT)
E85 Flex Fuel capable
U-flow Cooling
Electronic throttle control
