2010 "LSA" 6.2L V-8 SC ( LSA ) 5/06/2009
Type: 6.2L Gen IV V-8 Small Block
Displacement: 6162 cc (376 ci)
Engine Orientation Longitudinal
Compression ratio: 9.1:1
Valve configuration: Overhead valves (2 valves per cylinder)
Assembly site: Silao, MX
Valve lifters: Hydraulic roller
Firing order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x stroke: 103.25 x 92 mm
Fuel system: Sequential fuel injection
Fuel Type: Premium required
Maximum Engine Speed: 6200 RPM
Emissions controls:
Catalytic converter
Three-way catalyst
Valves per cylinder 2
Bore Center (mm) 111.76
Applications: Horsepower: hp ( kw )
Cadillac CTSV 556 hp ( 415 kW ) @ 6100 rpm SAE CERTIFIED
Applications: Torque: lb-ft ( Nm )
Cadillac CTSV 551 lb-ft ( 747 Nm ) @ 3800 rpm SAE CERTIFIED
MATERIALS
Block: Cast aluminum
Cylinder head: A356-T6 rotocast cast aluminum
Intake manifold: Cast aluminum
Exhaust manifold: High silicon / high moly cast iron
Main bearing caps: Nodular Iron
Crankshaft: Forged steel
Camshaft: Hollow steel
Connecting rods: Forged powder metal
Additional features:
1.9 L/rev Supercharger
Integrated single coolant to air intercooler
Piston oil spray cooling
Direct mount ignition coils
