Postby yoda67 » Wed Feb 25, 2015 9:27 pm
I had to take off board my problem was programmer cheap s t got better one all good now .
I have read chip edit file write back all working now, but can someone point me to location off odo permanent error so I can edit that out thankyou
yoda67
Postby TazzI » Thu Feb 26, 2015 3:46 pm
yoda67 wrote:I had to take off board my problem was programmer cheap s t got better one all good now .
Not something that's been found yet!
Postby yoda67 » Sat Feb 28, 2015 11:27 am
can any one please give me a good ba xr6 eeprom dump as I had a system crash and lost mine thankyou
yoda67
Postby TazzI » Wed Mar 04, 2015 5:32 pm
yoda67 wrote:can any one please give me a good ba xr6 eeprom dump as I had a system crash and lost mine thankyou
Whatevers in the thread is what you get! ;)
Postby LangasLS » Wed Mar 04, 2015 6:26 pm
What cluster have you got Yoda? There are two good BA dumps in the first post of this thread.
Postby yoda67 » Wed Mar 04, 2015 9:38 pm
thankyou I just sort it out friend had dash read from it. I flashed to my dash all working now, just got to find where permanent codes or in hex and that would be tops :)
yoda67
Postby LangasLS » Thu Mar 05, 2015 2:50 pm
What do you mean by 'permanent codes'? A heap of the locations for various functions have been figured out and are in this thread.
Postby TazzI » Thu Mar 05, 2015 6:29 pm
LangasLS wrote:What do you mean by 'permanent codes'? A heap of the locations for various functions have been figured out and are in this thread.
When the cluster is programmed by a scantool, it stored a permanent code/fault in the cluster that says "Odo programmed". I personally dont see how this is a issue at all really. I cant imagine anyone is going to have the relevant scantool to pop onto a BA/BF ford to purposely look for this code.
Simply means, to the average joe, a new cluster was fitted from the dealership and was programmed using their tools. Well, thats what I would assume.
Postby LangasLS » Thu Mar 05, 2015 7:48 pm
Interesting to know! So on any cluster that's been zero'd and programmed you will be able to see in the DTC's that it has been programmed?
Postby aumatt » Thu Mar 05, 2015 9:51 pm
Yes a permanent DTC is set when a zero km cluster is programmed with a scantool. This is stored in the DTC table in the eeprom. There is also a change counter, that increments evetytime you change the odometer below 100km. An example of this is dealer adds 20km on a new car, they can zero it(count 1), drive another 20km, zero again(count 2), zero again, drive another 20km zero again then the cluster will lock any further changes via obd.
