[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4775: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3841)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4777: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3841)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4778: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3841)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4779: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3841)
www.carmodder.com • View topic - Reversing FG Bluetooth Phone Module
Postby G6EKev » Mon Oct 12, 2015 10:59 am
G6EKev
Postby TazzI » Mon Oct 12, 2015 11:32 am
Postby G6EKev » Mon Oct 12, 2015 12:33 pm
G6EKev
Postby TazzI » Tue Oct 13, 2015 11:05 am
Postby G6EKev » Wed Oct 14, 2015 7:27 pm
Got another BPM today...
8R29 19C112 CA
Installed and tested no worries at all! All modules pass the Network Test
I have not figured out how I managed to damage the older BPM but now that the new module is working, so I'll start taking f/w dumps.
Connecting to an Australian Ford...
I cannot connect to the FG without using the automatic option. To connect, I go 'Start New Session', 'All Other'. The vehicle is detected right away and everything works as it should.
Installing the BPM...
Module Identification 1st to determine if the BPM is present and at least semi functional.
Module Programming, Programmable Module Installation, BPM - to install the BPM. Follow the procedure but do not turn the ignition key.
G6EKev
Postby TazzI » Thu Oct 15, 2015 11:26 am
Postby G6EKev » Thu Oct 15, 2015 12:16 pm
G6EKev
Postby TazzI » Fri Oct 16, 2015 1:08 am
Postby hunty19 » Mon Mar 06, 2017 6:13 pm
I might be offtrack with this, but it;s a bluetooth problem with 2008FG Xr6 with premium sound. Samsung Galaxy s2 2011MY using bluetooth V3 works great.Huawei P7 MY2016 using Blue tooth V4 connects well, but no conversation either way. I have been thinking that an upgrade of the ICC Bluetooth module to the "CA" version may fix the problem. Part NO BPM1008642. Is that too simple a solution, or is there much more to do?. Even with Bluetooth V4 there are subsets in the spec , ie 4.1, 4.2. I am hoping all level 4's will work. anyone know the answer?
hunty19
