Key programmer for 2014 FG MKII
Postby Mactagish » Thu Nov 17, 2016 11:23 am
Hi all,
Is there a key programmer that will allow me to delete old keys and add new ones to the computer on my falcon? When I bought it, it only came with one key and ford want $610 to replace the second one. Ouch!
I figure I can buy the programmer, key and have it cut for about half that.
Mactagish
Postby LangasLS » Sun Dec 11, 2016 12:16 pm
Best way is to use Ford IDS. Keys are programmed to the BCM, then that stored data is shared with the ecu during the parameter reset procedure.
Some locksmiths are able to copy a working keys transponder data, which can get you out of trouble, however there is no real easy way to delete other keys etc without using IDS.
I believe some scantools - gscan and launch x431 have the functionality to do them depending on software versions etc.
  • In total there are 15 users online :: 0 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 15 guests
