ve omega with calais colour headunit battery drain
Postby Lippyazfuq » Sat May 20, 2017 7:12 pm
hello everyone, i recently did a calais/ssv headunit conversion into our ve omega station wagon and modded the hvac module with resistors now the battery goes flat over night, i disconnected the hvac module thinking maybe i did something wrong with the resistors but its still going flat what would cause this ? thank you
Lippyazfuq
Postby TazzI » Mon May 22, 2017 2:43 pm
Did you get suitable patch harness done for the series2 unit?
Postby Cammed6litre » Fri Jul 07, 2017 5:06 pm
Might need to run over the harness with a volt metre or light man :) turn all power off and find the live wire that isn't a constant 12v
Sent from my Pixel XL using Tapatalk
Cammed6litre
Postby Lippyazfuq » Wed Jul 26, 2017 1:19 pm
***fixed*** turned out to be the cd stacker unit was plugged in the wrong way rookie mistake. thanks guys
Lippyazfuq
