Calais memory seats into any other model
Postby Eha002 » Thu Jan 23, 2014 11:12 pm
Im currently putting seats from a calais-v into my omega. Seats had leather burnt on them. Passenger seat even melted backrest tilt motor and wiring.
But as i havent seen it anywhere else, i thought id do a writeup along with the process of "skinning" seats and moving foam and covers between frames(if you have an ssv for example and want memory functions but don't want to lose your sporty ss-v leather seats), as well as the wiring.
I will also upload the wiring diagram from a Gregory's manual.
Stage 1:Wiring - complete
Stage 2: Seat removal
Stage 3: Skinning
Stage 4: Installation
Eha002
Postby silversv6 » Wed Jan 29, 2014 1:01 pm
I think the "memory" seats are controlled by the BCM which links to each key. Not sure if the omega BCM will do the job or if it can be reprogrammed for it. The gregorys manual are very brief for wiring etc. I have found the Haines manuals a lot more detailed. cheers
Postby davejames73 » Sat Aug 23, 2014 4:55 pm
Thanks for the pics worked a treat!
davejames73
Postby Gdicko » Fri Mar 18, 2016 11:29 am
I have 2007 ve gts, im putting calias front seats in, have different wiring, wonderin. If it can be wired as i have. Less extra wiring on calias seats any info would be great or diagrams
Cheers Glenn
Gdicko
Postby Fatboy15 » Mon Sep 11, 2017 4:30 am
Any luck
Fatboy15
  • In total there are 53 users online :: 0 registered, 0 hidden and 53 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 53 guests
