Ve E1/E2 gauge modules help please
Postby Voodoojezza » Mon Jul 17, 2017 11:27 pm
Hi everyone ive got a ssv my9.5 im wanting to put the binncle gauges in problem is i have two sets one e1 and one e2 the e2 looks better and is in better condition but has no module can i use the e1 module even though the read outs on gauges are different or will i need to calibrate the gauge i see you can buy new faces off ebay but the look of the e2 face appeals to me more
hope this all makes sense
cheers
Jezza'
Voodoojezza
Postby TazzI » Tue Jul 18, 2017 6:34 pm
Mix and Matching gauges with different series master modules = Incorrect readings.
If you want to use the E2 gauges, you will need to get E2 module. They are unfortunately not cheap so it will cost a bit to get the E2 gauges up and running.
Your best (And much cheaper!) option is to use the E1 gauges.
  • In total there are 53 users online :: 1 registered, 0 hidden and 52 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: Bing [Bot] and 52 guests
