Commodore VC Modern VDO Gauge Conversion
Specific interior modification information for Holden Commodore VB, VC, VK Series Commodores, and HDT models
Postby Rerouter » Wed Nov 12, 2014 7:39 pm
This is a project I undertook about 3 years ago, but am willing to post to give other members ideas on what can be done,
Apart from the speed sensor all wiring to the vehicle was done through the original plug, The center warning light panel was retained, and had a metal plate overlaid to mount the new gauges to,
The Speedometer and Tachometer are 100mm Gauges, with the oil and temp 52mm gauges, there was no fuel mounted as the customer already had a separate LPG gauge elsewhere in the vehicle.
Rerouter
Images: 6
Postby silversv6 » Fri Nov 14, 2014 2:00 am
I done a similar thing in 2000 with a VK cluster. I kept the original oil pressure, voltmeter, fuel & temp gauges & fitted a VP speedo & tacho. Made a new voltage regulator & split it between the gauges as the circuit board had to be cut to fit the VP tacho & speedo. The rear of mine looks just like yours....wires everywhere! cheers
