ECUs, ODBII DTCs and PIDs
vz v6 cranks over no start code P0513
Discuss Diagnostic Trouble Codes and Parameter IDs for the Holden VY and VZ Commodores, Pontiac GTO, Vauxhall Monaro, and Chevrolet Lumina Models
Postby silversv6 » Mon Jul 22, 2013 12:17 am
Any spark or just no inj pulse? I know VP immob is completly differennt, but was just a thought you may have missed
Postby doubledip » Mon Jul 22, 2013 6:30 am
Anything else been replaced programmed. Need to tell us full story
Why was this all done in first place
Postby mitchelldrysdale » Mon Jul 22, 2013 12:19 pm
It sounds like there was an issue in the linking process. If you can try linking the bcm-pim-pcm again
mitchelldrysdale
Postby mitchelldrysdale » Mon Jul 22, 2013 12:25 pm
Extract from Holden VZ V6 service information
Conditions for setting:
DTC P0513: The ECM receives an incorrect response from the PIM during the theft deterrent security authentication process
mitchelldrysdale
Postby kfrahm » Tue Jul 23, 2013 3:03 pm
Vehicle was bought from auction without BCM have fitted new BCM and keypad which have been programmed with tech2 BCM/PIM/ECM link also done with tech2 and security authentication through TIS and tech2, customer has also fitted new fuel pump as he thought that was the problem.
kfrahm
Postby doubledip » Tue Jul 23, 2013 3:35 pm
Who linked it ?
Sounds like as said before the immobiliser code hasn't been linked properly or a faulty ecu.
Postby kfrahm » Tue Jul 23, 2013 7:37 pm
Was linked at holden dealership
kfrahm
Postby mitchelldrysdale » Tue Jul 23, 2013 9:54 pm
If it was mine i'd be with tech2 looking at all the data to see what state each module is in, if there is one which is not disarming correctly
mitchelldrysdale
Postby doubledip » Tue Jul 23, 2013 10:07 pm
check the basics
got fuel pressure
got spark
go injector pulse
if missing any of these then check power at the injector plugs
power at the coil plugs
power at the fuel pump
Postby silversv6 » Thu Jul 25, 2013 11:34 pm
If the PIM has been replaced it must be reset in the original car before fitting into another car. The PIM can only be reset 8 times maximum as well. Did you use the correct security code for the car when linking the PIM? Also make sure the battery is fully charged while linking. (good battery, not an old shit battery) If you have done all correctly...Try coding another key. Sounds like the key or key reader may not be working.
Return to ECUs, ODBII DTCs and PIDs
