car cranks over so not key or key reader
if you use the wrong code it fails.. wont succeed when programming
the code it is showing is that the ecu/PIM don't have the same matching immobiliser code stored in each other... sounding like the ECU maybe at fault if it is the only thing not replaced/programmed
