ECUs, ODBII DTCs and PIDs
VZ SV6 High beam indicator light on instrument cluster
Discuss Diagnostic Trouble Codes and Parameter IDs for the Holden VY and VZ Commodores, Pontiac GTO, Vauxhall Monaro, and Chevrolet Lumina Models
Postby carcher » Thu Apr 12, 2012 7:55 pm
VZ SV6 High beam indicator light on instrument cluster on, even when key is switched off.
Any ideas as to what this would be?
carcher
Postby ZerOne » Sat Apr 14, 2012 4:55 pm
Sorry for the late reply....
I am not sure if my wiring diagram information is correct, but it looks like the high beam line (Coming from the Normally Open Output of the High Beam Relay) is connected to both the High beams, and the cluster.
(I need to confirm this though)....
Are you high beams constantly On, as well as the high beam indicator ???
Do the High beams work normally (I.E. if you pull to flash, that works, and if you push the stalk forward, the high beams turn on as well) ????
The reason for the questions is it could possibly be either one of the following,
1) The cluster may be faulty (Highly unlikely though)
2) The High Beam indicator wire could be touching ign or constant power.
3) The high beams may be on all the time. (And may not turn off).
Let me know the results of the above test, and I will try and find detailed wiring information to try and work out what the cause may be.
Cheers, and welcome to the forums :)
Return to ECUs, ODBII DTCs and PIDs
