2010 Hydra-Matic 6L90 Transmission ( MYD ) 06/05/2009
Type: six speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module
Maximum engine power: 452 bhp ( 337 kW ), Diesel: 300bhp ( 223kW ) - Truck
555 bhp ( 414 kW ) - Passenger car
Maximum engine torque: 531 lb-ft ( 720 Nm ), Diesel: 520 lb-ft ( 705 Nm ) - Truck
550 lb-ft ( 746 Nm ) - Passenger car
Maximum gearbox torque: 885 lb-ft ( 1200 Nm )
Gear ratios: MYD
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: -3.06
Maximum shift speed 6200 rpm
Maximum Validated Weights: ( Target ) GVW: 15000 lb ( 6803 kg ), GCVW: 21000 lb ( 9525 kg )
7-position quadrant: P, R, N, D, X, X, X ( X = available calibratable range position )
Case description: 3-piece ( Bell, main, extension )
Shift pattern: (2) Three-way on/off solenoids
Shift quality: Five variable bleed solenoid
Torque converter clutch: Variable Bleed Solenoid ECCC
Converter size: 300mm ( reference )
Fluid type: DEXRON® VI
Fluid capacity: w/ 300mm converter 300mm: 13.0L ( 10.8kg )
Transmission weight: w/ 300mm converter Wet: 109kg ( 240lb ) estimated
Pressure taps available: line pressure
Assembly Site:
GMPT Ypsilanti, MI
GMPT Toledo, OH
GMPT Silao, MX
Applications:
Chevrolet Suburban H.D.
GMC Yukon XL H.D.
Chevrolet Silverado HD
GMC Sierra HD
Cadillac CTS-V
Chevrolet Express
GMC Savana
Available Control Features:
Multiple Shift Patterns ( Selectable )
Driver Shift Control ( Tap Up / Tap Down )
Enhanced Performance Algorithm Shifting ( PAS )
Selectable Tow / Haul Mode
Engine Torque Management On All Shifts
Altitude and Temperature Compensation
Adaptive Shift Time
Neutral Idle
Reverse Lockout
Automatic Grade Braking
Additional Features:
OBDII / EOBD
Integral Electro/Hydraulic Controls Module ( Tehcm )
Control Interface Protocol - GMLAN
