2010 Tremec TR6060 (MZ6) 5/06/2009
Type: Rear wheel drive, six-speed manual overdrive transmission
Engine range: 6.2L ( LS3 )
Maximum engine torque: 430 lb-ft ( 580 Nm )
Maximum gearbox torque: 430 lb-ft ( 580 Nm )
Gear ratios: MZ6
First: 2.966
Second: 2.066
Third: 1.426
Fourth: 1.000
Fifth: 0.710
Sixth: 0.562
Reverse: 3.276
Final Drive Ratio: 3.420
Maximum validated gross vehicle weight: 4000 lb ( 1680 kg )
Case material: Aluminum
Center distance: 85mm
Fluid type: Texaco ATF Type III 1863
Transmission weight: Wet: 54.9 kg (121 lb )
Fluid capacity (approximate): Dry: 3.8L (4.0 qt) 117 oz.
Power take off: No
Applications: Corvette Grand Sport Coupe and Convertible
