Upgrading VE Commodore Instrument Clusters
Postby Warnererank » Wed Jan 16, 2019 9:47 pm
Hi
Can someone please confirm the type of bulb used in the instrument cluster on a 155 V6. The cluster has been changed due to corrosion recently however I need at least 4 bulbs.
Thanks
Warnererank
Postby EddieSSkash » Sun Jun 09, 2019 8:09 pm
If you check out the forums of most people who upgraded, you will see that a single GTX 560Ti, GTX 570, or GTX 580 will work fine. Yes, there will be bottleneck on the card, but that is something you will have to live with if you are on that board.
You will also have a lot of CPU bottleneck, so upgrading to any of them is going to limit the cards full potential.
A GTX 590 is a no go without upgrading the PSU, and will be severely bottlenecked on the current system.
EddieSSkash
  • In total there are 34 users online :: 1 registered, 0 hidden and 33 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: Bing [Bot] and 33 guests
