PUBLIC: Holden VY/VZ Instrument Cluster EEPROM Programming
Postby riddler2608 » Mon May 13, 2013 5:02 pm
since im playing around is there any areas that are unknown? Then I can look more around those areas and we can get this whole eeprom data worked out?
riddler2608
Postby TazzI » Mon May 13, 2013 7:04 pm
riddler2608 wrote:im going to make up a mode button for my test rig can anyone please tell me what the resistance is for each of the buttons.(ie mode, set, up, down)that would be greatly appreciated .
Never actually measured, Id assume it be easiest grabbing the mode/set buttons from wreckers and wiring them in?
riddler2608 wrote:since im playing around is there any areas that are unknown? Then I can look more around those areas and we can get this whole eeprom data worked out?
Ah, the "main" bits needed to reprogram a cluster are in that excel sheet, so base the unknown locations off that.
Some locations you can change and see no effects, can be because they need to be set to a specific value in order for something to change or because they are simply calibration numbers/software versions which dont change anything.
Postby sszls1 » Sat May 25, 2013 11:41 pm
2 X VZ Bins attached:
1) My VZ LVL1 SS dash (but I have changed VIN#)
Used VZ LVL1 Cluster 148123km.bin
2) A New VZ LVL2 AWD that has been plugged into a car and powered on but not programmed with Tech2. (basically just 00 and FF filled in the bin)
New Virgin VZ LVL2 Cluster.bin
I also have put together an Excel spreadsheet for VZ's that I could upload, I will wait for advice from a Moderator/Admin before posting it up. I have identified locations for:
ODO Reading (KM)
PPK (Speedo Calibration)
PPR (Tacho Calibration)
Fuel Tank Sender Ohms
Next Service (KM)
Last Service (KM)
Serial #
GM Part Number
Service Interval (KM)
Year of Manufacture
VIN
Fuel Tank Calibration #
Fuel Tank Calibration Litres (X2)
Fuel Tank Capacity (X2)
Likely Temperature Gauge Calibration
Likely LED Brightness
Police Mode
SRS (Airbag) Config
Auto/Manual
Fuel Gauge Calibration (L x2)
Likely Overspeed Settings
RPM settings per gear for shift light (multiply by 50 = RPM)
Likely Rest Reminder
Likely Build Date
Likely Custom Text
Those listed as "Likely" I have not tested but I'm fairly confident they are correct.
Jamie
sszls1
Postby VL400 » Wed Jun 26, 2013 12:04 am
Great work on all this cluster modding :D Have been playing around with a VY with lots of help from Tazzi, attached is a VY level 3 series 2 bin before it got massaged for my VL.
VL400
Postby VL400 » Wed Jun 26, 2013 12:18 am
riddler2608 wrote:hi guys
Thanks Aaron
Prob already got this sorted but you need the following..
UP: 3.4V = 10K
Down: 2.57V = 4.7K
Mode: 4.09V = 20K
Set: 4.51V = 40K
VL400
Postby vpgts076 » Sun Jun 30, 2013 9:58 pm
Hi Guys / Girls,
been following this thread for a while a finally managed to extract a bin out of my cluster.
It is a
VZ Executive
208,850 KMS
V6
Auto...
Enjoy.
Thanks
Daniel
vpgts076
Postby vpgts076 » Tue Jul 02, 2013 2:32 pm
Thanks Aaron
UP: 3.4V = 10K
Down: 2.57V = 4.7K
Mode: 4.09V = 20K
Set: 4.51V = 40K
Hi mate,
are these part of the switch? ie if you use a Vy / Vz switch will; it be ok?
thanks
Daniel
vpgts076
Postby VL400 » Tue Jul 02, 2013 5:12 pm
They should be part of the switch, but cant confirm they are the same between VY and VZ. The values were just what I used modding a VS switch to work with a VY cluster.
VL400
Postby vpgts076 » Tue Jul 02, 2013 7:42 pm
VL400 wrote:They should be part of the switch, but cant confirm they are the same between VY and VZ. The values were just what I used modding a VS switch to work with a VY cluster.
Thanks Mate,
That's what I want to do....
Did you place them on wire or inside switch?
Thanks
Daniel
vpgts076
Postby VL400 » Wed Jul 03, 2013 11:28 am
This is heading off topic so mods might need to split it (and if they can enable my account to start new threads that would be great :) )
This is the inside of the VS switch...
VL400
  • In total there are 135 users online :: 0 registered, 0 hidden and 135 guests (based on users active over the past 5 minutes)
  • Users browsing this forum: No registered users and 135 guests
