[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 483: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4775: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3841)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4777: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3841)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4778: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3841)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4779: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3841)
www.carmodder.com • View topic - VE Radio / HVAC EEPROM reprogramming information
Postby 91C02920 » Fri Jan 12, 2018 6:43 am
I have an IQ unit from a US Caprice (in a Caprice) and I was able to unlock the Driving Lockouts for Phone and Navigation by programing it with GM SPS and using a vin from a Brazilian Chevy Omega, apparently they are not locked out in Brazil, and then after it was programed, changing the vin on the eprom to my vin. (note: of course I don't have nav, but the driving lockout is select-able for it).
Is there a region where DVD isn't locked out from the factory and I could use the same method to program with a vin from that region to unlock that also?
91C02920
Postby GXP25 » Thu Jan 18, 2018 12:39 pm
Anyone?
GXP25
Postby TazzI » Thu Jan 18, 2018 2:17 pm
Postby GXP25 » Wed Jan 24, 2018 6:19 am
GXP25
Postby TazzI » Wed Jan 24, 2018 10:02 am
Its easy to say "surely someones figured it out", but finding specific things can take thousands of attempts/flashing and 100's of hours. Which is why alot of peoples works is not disclosed publicly either due to the time invested.
Generally things are worked out by comparing two eeproms, where one has the desired setup and the other does not. Your situation is the less favorable one, where youll need to trial and error random locations to see what changes and hope to stumble across what your after (If its even possible).
Postby jezzab » Wed Jan 24, 2018 1:33 pm
Yes, the master and slave HVAC dial can be swapped for LHD (only tested on IQ though). I don't know the EEPROM location sorry as I do I via CAN bus, so it wont be any help to you.
Postby Ruley » Mon Apr 16, 2018 9:46 am
Hi all,
Hopefully you can all help me out. I've been doing a lot of research and reading and I was wondering if I start flashing the A2 block(DID) on the IQ(through the can bus) trying to enable things like RSE, DVD, & Reverse cam amongst some other things is there any chance of bricking the IQ or making it unusable. Or is that completely the wrong block of data to be modifying to enable those things
Cheers Ruley
Ruley
Postby Ruley » Wed Apr 18, 2018 9:42 am
Ruley
Postby GXP25 » Thu May 17, 2018 10:21 am
GXP25
Postby GXP25 » Thu May 17, 2018 10:23 am
GXP25
  • Most users ever online was 151 on Fri Mar 03, 2017 1:44 pm
