Mazda Renesis Rotary Wankel Engine
Mazda 13B-MSP Renesis Rotory Wankel Engine Information
Discuss Modifications, Service, and Technical information for the Mazda Renesis (1.3L) Rotary Wankel Engine (2004 Onwards)
Postby ZerOne » Thu Jul 21, 2011 8:37 am
The Mazda Wankel engines (a type of rotary combustion engine) are family of car engines derived from experiments in the early 1960s by Felix Wankel, a German engineer. Over the years, displacement has been increased and turbocharging has been added.
Wankel engines can be classified by their geometric size in terms of radius (rotor center to tip distance, also the median stator radius) and depth (rotor thickness), and offset (crank throw, eccentricity, also 1/4 the difference between stator's major and minor axes). These metrics function similarly to the bore and stroke measurements of a piston engine. Displacement is 3√3radius·offset·depth, multiplied with the number of rotors (note that this only counts a single face of each rotor as the entire rotor's displacement). Nearly all Mazda production Wankel engines share a single rotor radius, 105 mm (4.1 in), with a 15 mm (0.6 in) crankshaft offset. The only engine to diverge from this formula was the rare 13A, which used a 120 mm (4.7 in) rotor radius and 17.5 mm (0.7 in) crankshaft offset.
Mazda rotary engines have a reputation for being relatively small and powerful at the expense of poor fuel efficiency. They are starting to become popular with kit car builders, hot rodders and in light aircraft because of their light weight, compact size, and tuning potential stemming from their inherently high power to weight ratio[citation needed].
In auto racing, the displacement of a Wankel engine is usually doubled for classing purposes. For calculating taxes in Japan, the displacement of Wankel engines is defined as the equivalent of 1.5 times the nominal displacement, so the 1300 cc 13B engines are taxed as 1950 cc.
When Wankel engines became commonplace in motor sport events, this created the problem of accurate representation of each engine's displacement, for the benefit of competition. Rather than force the majority of participants (driving piston engine cars) to half their quoted displacement (likely resulting in confusion), most racing organizations simply decided to double the quoted displacement of Wankel engines.
The Renesis engine – also 13B-MSP (Multi Side Port) – which first appeared in production in the 2004 Mazda RX-8, is an evolution of the previous 13B. It was designed to reduce exhaust emission and improve fuel economy, which were two of the most recurrent drawbacks of rotary engines. Unlike its predecessors from the 13B range, it is naturally aspirated, leading to lower power from its two versions Mazda RX-7's twin-turbocharged 13B-REW (280 hp).
The engine entailed two major changes. First, the exhausts ports are no longer peripheral but are located on the side of the housing, which allowed engineers to eliminate overlap and redesign the intake port area. This produced noticeably more power, thanks to a better compression ratio. Second, the rotors are shaped differently, especially their side seals and low-height apex seals, which offer optimized lubrication.
These and other innovative technologies allow the Renesis to achieve 49% higher output and dramatically reduced fuel consumption and emissions (the RX-8 meets LEV-II). It won International Engine of the Year and Best New Engine awards 2003 and also holds the "2.5 to 3 liter" (note that the engine itself is 1.3 liter) size award for 2003 and 2004, where it is considered a 2.6 L engine. Finally, it was on the Ward's 10 Best Engines list for 2004 and 2005.
The Renesis has also been adapted for a dual-fuel use, allowing it to run on gasoline or hydrogen.
All the Mazda rotary engines have been praised, because of their light weight. The unmodified 13B-MSP Renesis Engine has a weight of 122 kg (247 lbs), including all standard attachments (except airbox), but without engine fluids (such as coolant, oil, etc.).
Return to Mazda Renesis Rotary Wankel Engine
