Mazda B SOHC/DOHC 4 Cylinder Engine
Mazda B SOHC/DOHC 4 Cylinder Information
Discuss Modifications, Service, and Technical information for the Mazda B SOHC and DOHC Engine (1985-Onwards)
Postby ZerOne » Thu Jun 30, 2011 7:46 am
The Mazda B-series engine is a small-sized, iron-block, inline four cylinder with belt-driven SOHC and DOHC valvetrain ranging in displacement from 1.1L to 1.8L. It was used from front-wheel drive economy applications to the turbocharged full-time 4WD 323 GTX and rear-wheel drive Miata as well as numerous other models. The Mazda B-series is a "non-interference" design, meaning that breakage of its timing belt does not result in damage to valves or pistons, because the opening of the valves, the depth of the combustion chamber and (in some variants) the shaping of the piston crown allow sufficient clearance for the open valves in any possible piston position.
B1 4 Cylinder Engine Series
1.1 L (1,138 cc) B1 - (68.0x78.4 mm) - came only as a SOHC 8-valve. It was available in the 1987-1989 Mazda 121 and later model Kia Pride in European and Asian markets. A fuel injected variant was used in select European market 1991-1995 Mazda 121s
BJ 4 Cylinder Engine Series
The 1.3 L (1,290 cc) BJ engine (78.0x67.5 mm) was a DOHC 16-valve engine, used only in the Japanese market Ford Festiva GT-X and GT-A (1989.03-1993.01, GT-A from March 1991). It developed 88 PS (65 kW) at 7,000 rpm and was equipped with Mazda's "EGi" single-point fuel injection. It was a short-stroke version of the B5/B6 engines.
B3 4 Cylinder Engine Series
Mazda B3E
1.3 L (1,324 cc) B3 - (71.0x83.6 mm). It was available in SOHC and DOHC variants and was found in the Kia-built 1988-1993 Ford Festiva, the 1987-1989 Mazda Familia and it's derivatives, as well as the Mazda 121 (also known as Autozam Revue) (54 hp and 72 hp version), and the 1987-1989 Ford Laser, and 1994-1997 Ford Aspire. Later variants were used in the Mazda Demio microcar as late as 1999.
Horsepower: Fuel injected 63 hp (47 kW) @ 5000 rpm Torque: 73 ft·lbf (99 N·m) @ 3000 rpm Carburated58 hp (43 kW)
Later versions (mazda 323 91-98 etc.) produced 73 hp (54 kW) at 5,500 rpm, and 80 ft·lbf (110 N·m) of torque at 4,000 rpm[2]
1988-1993 Ford Festiva/Mazda 121
1985- Kia Pride
Autozam Revue/Mazda 121
1986-1989 Mazda Familia/323
1995-1999 Mazda Demio
1994-1997 Ford Aspire/Kia Avella
1991-1993 Sao Penza
B5 8-valve 4 Cylinder Engine
1.5 L (1,498 cc) B5 - (78.0x78.4 mm) - The SOHC 8-valve B5 upped the displacement to 1.5 L and was found in the 1987-1989 Mazda Familia, the 1987-1989 Ford Laser. It was also fitted to the Mazda Étude coupé and fifth generation BF-series Familia Wagon, as it continued in production until 1994 along the new BG.
B5 16-valve SOHC 4 Cylinder Engine
There was also a 16-valve, SOHC B5-MI version of the B5, usually fitted with single-point fuel injection ("EGi"). This engine was mainly used in the Japanese domestic market. The B5-ME, equipped with electronic fuel injection, was used by Kia for several of their cars as well as in the Mazda Demio.
B5 16-valve DOHC 4 Cylinder Engine
1.5 L (1,498 cc) B5D - (78.0x78.4 mm) - A Japanese-only variant of the B5 with fuel injection and revised head/intake system. Found in the 1989-1994 BG Familia and Ford Laser S. Power output is 120 PS (88 kW) at 6,500 rpm and 13.5 kg·m (132 N·m; 98 lb·ft) at 5,500 rpm.[4] The Timor S515i also used a B5D, with 110 PS at 5,500 rpm and 145 Nm at 4,400 rpm without variable valve timing and with a 9.2:1 compression ratio. The B5D was also found in the Autozam AZ-3, a Japanese market version of the Mazda MX-3, where it produced 120 PS (88 kW).
Later Familia 'Interplay X' versions (1994 on) have a B5-ZE engine which produces 125 PS (92 kW) at 7,000 rpm and 13.2 kg·m (129 N·m; 95 lb·ft) at 6,000 rpm
B6 Series 4 Cylinder Engine
1.6 L (1,597 cc) B6 — (78.0x83.6 mm) — This was a bored-out version of the B3. The 8-valve SOHC B6 was found in the 1985-1989 and 1990-1994 Mazda 323, the 1987-1990 Mercury Tracer, the 1992 Mazda MX-3, and the 1985-1990 Ford Laser.
In Japan and Australia a fuel-injected version called the B6F was available.
B6-2E Series 4 Cylinder Engine
1.6 L (1,597 cc) B6-2E - (78.0x83.6 mm), also known as B6-ME - This was a variant of the B6-E with a SOHC 16-valve cylinder head. It is found in the 1991-1994 Mercury Capri, 1992-1994 California-spec Mazda 323 and 1992-1993 Mazda MX-3. The B6-ME produced 88 hp (66 kW) and 96 ft·lbf (130 N·m). A carburetted version was used in 4WD versions of Japanese market BG Familias, where it produced 91 PS (67 kW) at 6,500 rpm and 13.0 kg·m (127 N·m; 94 lb·ft) at 3,000 rpm.[4]
B6T Series 4 Cylinder Engine
1.6 L (1,597 cc) B6T - (78.0x83.6 mm) - The ubiquitous turbocharged, fuel-injected and intercooled 16-valve DOHC B6, released in 1985 and used in numerous models worldwide including the 1985-1989 Mazda Familia BFMR/BFMP (turbo), 1985-1989 Ford Laser TX3 turbo, and later Mercury Capri's. This engine was most commonly found mated to a 4WD drivetrain although FWD models were also available.
Power and torque outputs varied across markets due to emission and fuel standards. The B6T available in North America came with 132 hp (98 kW) and 136 lb·ft (184 N·m). The Japanese version was slightly more powerful, producing 140 PS (103 kW) and 19.0 kg·m (186 N·m) due to better intake manifold design and its ability to run 100 octane fuel. For the special rally homologation BFMR Familia GT-Ae model released in 1987, power and torque were raised to 150 PS (110 kW) and 20.0 kg·m (196 N·m) respectively through the use of a slightly different turbocharger; engine internals remained otherwise identical.
B6D Series 4 Cylinder Engine
Mazda B6D, 3rd generation
1.6 L (1,597 cc) B6D - (78.0x83.6 mm) - The same strengthened and fuel-injected 16-valve DOHC B6 but with higher compression, no turbo, and the first Mazda engine to feature VICS (Variable Inertia Charge System). Most commonly found in the 1985-1988 Japanese market Familias, Études and Lasers, this engine was updated in 1989 with revised compression, heads and intake system (in a similar vein to the B5 DOHC) for the 1989-1991 Familia and Laser, then further refined for the 1991-1994 Mercury Capri and 1994 to 1996, second Generation Mazda MX-3 RS. The third generation B6D features an alloy cam cover, a VLIM (VICS) intake, had a 9:1 compression ratio and produced 107 hp (79 kW).
B6ZE(RS) Series 4 Cylinder Engine
1.6 L (1,597 cc) B6ZE(RS) - (78x83.6 mm) - Developed for the Mazda Miata (1989–93). The engine uses a DOHC 16-valve alloy head with a lightened crankshaft and flywheel to allow a 7,200 rpm redline. An aluminum sump with cooling fins is an unusual feature of this engine. The Japanese version of the engine had a 9.4:1 compression ratio and produced 120 hp (90 kW) and 100 ft·lbf (136 N·m).
B8 Series 4 Cylinder Engine
The 1.8 L (1,839 cc) B8 is not just a bored and stroked B6. Rather, it uses a new block with widened cylinder spacing. The bore is 83 mm and the stroke is 85 mm. This SOHC engine was used in various Australian Mazda 323s, the American 1990-1994 Mazda Protege, and in Canadian variants of the 323 hatchback. It came in both 8 (B8-E) and 16-valve variants (B8-ME). It features hydraulic lash adjusters, a belt-driven cam, an 8.9:1 compression ratio, a 6,000 rpm redline, and multi-port fuel injection. Power outputs are:
103 hp (77 kW), 111 lb-ft (U.S./Canadian market)[4]
106 PS (78 kW) at 5,300 rpm, 151 N·m (111 lb·ft) at 4,000 rpm (European markets)[4]
BP Series 4 Cylinder Engine
The 1.8 L (1,839 cc) BP is a dual-overhead variant of the B8. It was first found in the 1989 Mazda Familia and American-market 1990 Mazda Protege LX. This engine was dubbed BP-ZE and featured a forged crankshaft, piston oil squirters, a structural aluminum oil pan with cooling fins, a 7,000 rpm redline, and the Variable Inertia Charging System (VICS). This particular variant can be found in the following vehicles:
1989-1994 Mazda Familia GT (European & Australian Market)
1989-1994 Ford Laser TX3 (Australian Market)
1990-1994 Mazda Protege LX (with VICS)
1995-1998 Mazda Protege ES (Australian Market: 1994-1998 323 Protege SE)
1990 Mazda Infini
1990-1991 and 1993 Mazda Protege GT (Canadian Market)
1990-1993 Mazda 323 (European Market)
1991-1996 Ford Escort GT and LX-E
1991-1996 Mercury Tracer LTS
1995-1997 Kia Sephia RS, LS, GS
1994-1998 Mazda Familia (Japanese Market)
1994-1997 Mazda MX-5/Miata (did not have VICS until 1999)
There is also a non-performance version that is most easily recognized by its black stamped-steel oil pan. It also features a cast crankshaft, no oil squirters, a plastic oil pickup tube and less aggressive camshafts. It is found in the 1995-1998 Mazda Protege ES.
BPT Series 4 Cylinder Engine
Mazda BPT - Turbocharged 1.8L
The BPT is a turbocharged and intercooled variant of the BP. It produced 180 PS (132 kW) at 6,000 rpm and 24.2 kg·m (237 N·m; 175 lb·ft) of torque at 4,000 rpm in JDM-spec. 95 octane rated European models only claimed 166 PS (122 kW) at 5,500 rpm and 219 N·m (162 lb·ft) at 3,000 rpm.
It featured an IHI RHB5 VJ20 turbocharger, sidemount intercooler, 330 cc blacktop injectors (high impedance). The standard BPT ecu had a boost cut at 11psi. The BPT versions of the Familia and Laser were only available in 4WD models, and featured an open front differential and an viscous LSD rear differential. This engine is rumoured to have been installed in some Mazda MX-5 Miata models. Applications:
1989-1994 Mazda Familia GT-X (Japan)
1989-1994 Ford Laser TX3 turbo (Australia)
Ford Laser GT-X
BPD Series 4 Cylinder Engine
The mazda BPD engine (also commonly referred to as a BP2) was a revamp of the original BP engine (sometimes called BP1 for clarity's sake). It featured a larger crank nose, larger piston oil squirters, a main bearing support plate, better flowing inlet and exhaust ports. This was also the base engine for the Mazda Familia GT-R and GT-Ae. It is commonly known as the 'big turbo' variant as it utilised a much larger IHI RHF6CB watercooled turbocharger(vj23). The BPD was used as the basis for the engine, with changes such as sodium filled exhaust valves, larger (and front mounted) intercooler, larger (440 cc) low impedance fuel injectors and stronger engine internals helping to up the performance of the engine to produce 209 hp (156 kW) and 184 ft·lbf (255 N·m).The VICS system of the N/A BP has been removed, as well as the boost cut from the ecu. This engine was designed to power Mazda to a world rally championship win, and was thus used in the limited production Mazda Familia GT-R (2,200 built) and GTAe (300 built).
BP-4W Series 4 Cylinder Engine
The 1999 Miata uses a modified BP, the BP-4W, which replaces the old Hall Effect dual Cam Angle Sensor unit mounted at the back of the exhaust cam with two separate Hall Effect units at the front - one on the intake cam gear and one mounted on the oil pump, to the side of the crankshaft pulley. It also has an improved intake system (a better flowing cylinder head because of the angle of the intake ports being changed). The United States 2004-2005 Mazdaspeed MX-5 turbo is based on this engine rather than the newer BP-Z3 and produces 178 hp (133 kW) and 166 ft·lbf (225 N·m) with slightly-reduced compression. The Mazdaspeed turbo engine has no VICS, but does have VTCS which is often mistaken to be related to VICS.
Applications:
1999-2000 Mazda MX-5/Miata
2004-2005 Mazdaspeed MX-5 (turbo)
BP-Z3 Series 4 Cylinder Engine
In 2001, Mazda introduced the still 1.8 L (1,839 cc) BP-Z3 (also called BP-VE) variant of the BP engine. It features S-VT variable valve timing on the intake side, no more VICS, but there is Variable Tumble Control System (VTCS)in the BP-Z3. A similar looking but effectively very different set of valves that restrict the intake on cold start for emissions purposes, rather than the torque enhancing set of partial butterflies that increase velocity that are used in VICS. This was found in the 2001+ Miata. The Z family is an evolution of this engine.
In Australia, a turbocharged version of this engine produced 210 hp (157 kW) and 206 ft·lbf (280 N·m) in the Mazda MX-5 SP. The United States 2004-2005 Mazdaspeed MX-5 turbo is a BP-4W, not a BP-Z3.
Applications:
2001-2005 Mazda MX-5/Miata
Mazda MX-5 SP (Australian turbo)
Return to Mazda B SOHC/DOHC 4 Cylinder Engine
