Mazda R Diesel 4 Cylnder Engine
Mazda R Diesel 4 Cylinder Engine Information
Discuss Modifications, Service, and Technical information for the Mazda R Diesel Engine (1993-2009)
Postby ZerOne » Thu Jun 30, 2011 7:58 am
Straight-4 4 cylinder Diesel Engines
1.7 L PN - 1,720 cc - Used in the Mazda Familia and Ford Laser
2.2 L R2 - 2,184 cc - Used in the 1984 onwards Mazda Bongo
3.5 L SL - 3,455 cc -
4.0 L TF - 4,021 cc -
4.6 L TM - 4,553 cc -
3.0 L VS - 2,956 cc -
2.5 L WL - 2,499 cc - Turbodiesel, used in non-US 1995 Mazda MPV.
2.7 L XB - 2,701 cc - 81 PS, used in 1973 Mazda Parkway (AEXC), E2700 Van and T2700 Titan.[1]
3.7 L XC - 3,663 cc -
Perkins 4 cylinder Diesel Engines
These three engines (GA/GB/GC in Perkins' internal parlance) were developed especially for Mazda and were never offered by Perkins themselves.
2.2 L S2 - 2,209 cc - License built Perkins 4.135 related to HA and XA, used in 1979 to 1984 Mazda Bongo, B2200, Ford Ranger
2.5 L XA - 2,522 cc - License built Perkins 4.154 related to HA and S2
3.0 L HA - 2,977 cc - License built Perkins 4.182 related to S2 and XA
RF 4 cylinder Diesel Engines
Naturally aspirated SOHC, 2 valves-per-cylinder, displacing 1,998 cc with square internal dimensions of 86 mm (3.4 in) bore and 86 mm (3.4 in) stroke diesel RF engine was one of Mazda's more popular diesel engines. The R engine has virtually the same block as the Mazda petrol FE engine with identical bell housing pattern and block dimensions.
Used also in the 1984–1986 Ford Tempo - Mercury Topaz, the 1984–1987 Ford Escort - Mercury Lynx and pre-2001 turbo diesel Suzuki Grand Vitara
Used in the Mazda Bongo and 1999 Mazda Demio
Kia Sportage 1998-2003 Turbo-intercooler diesel variant released for Asia
RF 1998 4 cylinder Diesel Engines
Latest emission improved version used in Mazda 323 adopts a new swirl chamber with an enlarged volume, revised swirl-chamber-to-main-chamber ratio and a narrower throat area. Engine produces 52 kW (71 PS; 70 hp) at 4500 rpm on a raised 21.7:1 compression ratio, and has an exceptionally wide spread of torque throughout its range, peaking with 128 N·m (94 lb·ft) at 3000 rpm.
Further engine features:
optimized intake manifold, with inertia moment effect flow
camshaft with Mazda's Multi-Function cam profile theory (increases valve lift to 9.1 mm (0.4 in) and enhances the engine's volumetric efficiency at lower speed range, resulting in an improved torque output, never falling below 108 N·m (80 lb·ft) between 1,500 rpm and 4,500 rpm)
electrically controlled distributor-type fuel injection pump
electronically controlled EGR valve
Engines were mounted in:
Mazda 323 P 3D hatchback and 4D sedan since Juni 1997
Mazda 323 5D hatchback since August 1998
RF-CX Comprex 4 cylinder Diesel Engines
ABB Comprex pressure wave supercharger
56 kW (76 PS; 75 hp) at 4000 rpm, 172 N·m (127 lb·ft) at 2000 rpm
Used in JDM Capellas (1987–1991), introduced in June 1992 European Mazda 626
RF-T DI 1998 (2.0 DiTD) 4 cylinder Diesel Engines
A direct-injection turbo version (101 bhp) with four valves per cylinder, called the DiTD was introduced in the June 1998 Mazda 626 Wagon 2.0 DiTD. Engine has SOHC valve train with rocker arms and mechanically adjusted screws (no hydraulic valve lifters), with Denso V5 rotary injection pump and Denso PCM.
There were three power versions:
66 kW (90 PS; 89 hp) at 4000 rpm with maximum torque 220 N·m (160 lb·ft) at 1800 rpm
74 kW (101 PS; 99 hp) at 4000 rpm with maximum torque 220 N·m (160 lb·ft) at 1800–2200 rpm
81 kW (110 PS; 109 hp) at 4000 rpm with maximum torque 230 N·m (170 lb·ft) at 2000–2600 rpm
Mazda 323 5D hatchback and 4D sedan since August 1998 (66 kW version)
Mazda 323 5D hatchback and 4D sedan since January 2001 (74 kW version)
Mazda 626 Capella since June 1998
Mazda Premacy as DE 2.0L (DIREC-D) Euro III
RF 2002 (2.0 MZR-CD) 4 cylinder Diesel Engines
Next evolution of RF engine with common rail direct-injection was introduced in June 2002 European version Mazda 6 with output power 89 kW (121 PS; 119 hp) or 100 kW (136 PS; 134 hp) (both at 3500 rpm), depending on engine version (only difference between the two diesel drivetrains is the shape of their respective torque curves, the larger of the two engines being flatter). 2002 RF Mazda diesel engine includes new duel-mass flywheel and common rail Denso injection with max. pressure of 1800 bar, pilot and post-injection for operating smoothness and soft and acoustically unobtrusive combustion. Both versions have same compression ratio 18.3:1. Torque output (both versions have same maximum 310 N·m (230 lb·ft) at 2000 rpm), fuel efficiency and NOx emissions were improved by using:
expansive vertical vortex combustion (EVVC), which combines a special piston surface design, with ingenious fuel distribution, to produce a vertical swirl in the combustion chamber
variable turbine geometry (VNT) turbocharger
Combined fuel economy is achieving 6.5 litres per 100 km and emission rating Euro Stage III (D4) with on a regular basis mounted catalytic converter with Lambda probe and exhaust-gas recirculation system (EGR). Engines were mounted in (in order of appearance):
1st generation Mazda 6 Atenza (both versions) since June 2002
2nd generation Mazda MPV (only High Power version) since June 2002
RF 2005 (2.0 MZR-CD) 4 cylinder Diesel Engines
Production of improved, cleaner and more powerful common rail direct-injection turbocharged version of Mazda RF engine was started with July 2005 Mazda 6 facelift. This drivetrain still has most of typical features of its predecessor including belt-driven SOHC valve train with rocker arms and mechanically adjusted screws (in contrast to frequently mismatched, absolutely different Ford Duratorq ZSD or PSA DW10 engines). Mazda applied several technologies to this MZR-CD engine to achieve Euro Stage IV:
new variable geometry turbocharger has 14 percent less inertial moment and is more compact in design (achieved, for instance, by a shorter distance between the exhaust gas inlet and the turbine shaft)
Denso's 1800 bar second generation common rail system that, depending on driving conditions, uses multi-stage injection of up to nine times per cycle with six-hole injectors
relatively low compression ratio of 16.7:1 improves power output and torque(???), while at the same time helping to lower combustion noise and emissions
NOx emissions were reduced by lowering the engine's combustion temperature
O2 sensor constantly measures residual oxygen in the exhaust gases and this information is sent to 32-bit powertrain control module (PCM), which continuously optimizes the air/fuel mix
There were two power versions of this engine: Standard Power 89 kW (121 PS; 119 hp) at 3500 rpm and a maximum torque of 320 N·m (240 lb·ft) at 2000 rpm, High Power 105 kW (143 PS; 141 hp) at 3500 rpm and a maximum torque of 360 N·m (270 lb·ft) at 2000 rpm. Both versions come with a DPF system standard, which traps soot in a coated ceramic filter. As soon as the filter's storage capacity is exhausted, exhaust gas temperature is raised for a short period (using only diesel pre and post-injection techniques, not any fuel burner additive) and the particles burn off. As a result, the RF 2005 engines emit 80 percent less particulate matter than required by Euro Stage IV standards. Engines were mounted in (in order of appearance):
1st generation Mazda 6 Atenza (both versions) since July 2005
Mazda 5 Premacy (both versions) since January 2006
1st generation Mazda 3 Axela (only High Power version) since March 2007
RF 2007 (2.0 MZR-CD)v 4 cylinder Diesel Engines
Slightly detuned (103 kW (140 PS; 138 hp) at 3500 rpm and 330 N·m (240 lb·ft) at 2000 rpm) version of RF 2005 engine was introduced in November 2007's second generation Mazda 6. Newly calibrated powertrain control module mapping resulted in better drivability, fuel efficiency and emission performance. This engine has changed layout of the intake/exhaust, with more efficient EGR cooler, better DPF and combined fuel consumption 5.6 L/100 km (50 mpg-imp; 42 mpg-US), less than its predecessor. Engine was mounted in (in order of appearance):
2nd generation Mazda 6 Atenza since November 2007
R2 2008 (2.2 MZR-CD) 4 cylinder Diesel Engines
New generation RF-based MZR-CD 2.2-litre turbo diesel engine (stroke was lengthened by 8 mm (0.3 in) in comparison to the MZR-CD 2.0 RF engine) was introduced in November 2002 and this powertrain is planned to totally replace RF 2007 and RF 2005 in the future with three (or more, see below) power versions:
MZR-CD 2.2 High Power: produces 136 kW (185 PS; 182 hp) at 3500 rpm and 400 N·m (300 lb·ft) of torque from 1800 to 3000 rpm, with combined fuel efficiency in 2nd generation Mazda 6: 5.6 L/100 km (50 mpg-imp; 42 mpg-US)/5.7 L/100 km (50 mpg-imp; 41 mpg-US) and CO2 emissions of 149/152 g/km (sedan and hatchback/wagon).
MZR-CD 2.2 Mid Power: produces 120 kW (163 PS; 161 hp) at 3500 rpm and 360 N·m (270 lb·ft) of torque from 1800 to 3000 rpm, with combined fuel efficiency in 2nd generation Mazda 6: 5.5 L/100 km (51 mpg-imp; 43 mpg-US)/5.6 L/100 km (50 mpg-imp; 42 mpg-US) and CO2 emissions of 147/149 g/km.
MZR-CD 2.2 Low Power: produces 92 kW (125 PS; 123 hp) at 3500 rpm and 310 N·m (230 lb·ft) of torque from 1800 to 2600 rpm, with combined fuel efficiency in 2nd generation Mazda 6: 5.5 L/100 km (51 mpg-imp; 43 mpg-US)/5.6 L/100 km (50 mpg-imp; 42 mpg-US) and CO2 emissions of 147/149 g/km.
MZR-CD 2.2 Standard Power in 2nd generation Mazda 3 Axela (internal code BL): produces 110 kW (150 PS; 148 hp) at 3500 rpm and 360 N·m (270 lb·ft) of torque from 1800 to 2600 rpm, with combined fuel efficiency 5.6 L/100 km (50 mpg-imp; 42 mpg-US) and CO2 emissions of 144 g/km.
MZR-CD 2.2 with Selective Catalytic Reduction system in 2009 facelift Mazda CX-7 produces 127 kW (173 PS; 170 hp) at 3500 rpm and 400 N·m (300 lb·ft) of torgue at a low 2000 rpm, with combined fuel efficiency 7.5 L/100 km (38 mpg-imp; 31 mpg-US) and CO2 emissions of 199 g/km.
2.2 MZR-CD engine features:
Denso HP3-based common rail with system injection pressure increased to 2000 bar/200 MPa
common rail injectors that have 10 spray small (0.119 mm) holes (instead of the 6 used on the MZR-CD 2.0) and higher response solenoids
low compression ratio of 16.3:1, made possible with highly atomizing injectors
VNT turbocharger with curved vanes and abradable seal
chain-driven DOHC valve system
aluminium lower block combined with low-friction, front chain-drive balancer shaft
newly developed, high thermal resistance DPF system with global-first ceramic support matrix structure
newly developed EGR cooler
Euro Stage V emission rating
new Selective Catalytic Reduction (SCR) system with AdBlue additive significantly reduces NOx emissions (currently only in Mazda CX-7, in special 15.5-litre tank located under the luggage compartment, lasts over 20000 km under normal driving conditions)
electro-hydraulic power-assisted steering
Engine is mounted in (in order of appearance):
2nd generation Mazda 6 Atenza since November 2008 (High, Mid and Low power versions), MZR-CD 2.0-litre turbo diesel remains in the line-up in some markets
2nd generation Mazda 3 Axela (High and Standard power versions)
1st generation 2009 facelift Mazda CX-7
Engine is planned for (in order of appearance):
1st generation Mazda 5 Premacy (High, Mid and Low power versions)
Mazda 2.2 MZR-CD R2 engine has absolutely nothing to do with family of belt-driven PSA DW12B twin turbo engine, produced in Trémery or Ford Duratorq ZSD-422 VNT engine, produced in Dagenham.
Next generation 2.2 MZR-CD twin turbo called SKYACTIV-D
Introduced at the 41st Tokyo Motor Show
high fuel pressure common-rail system that controls piezo injectors
aluminium block
significantly reduced size and weight of reciprocating and rotating parts (aluminum block, lightweight pistons and connecting rods)
similar weight to the petrol version
wide-range, high volume EGR
two stage (twin turbo) turbocharger with high turbopressure over a broader engine rev range
PM oxidation catalyst-supported diesel particulate filter (DPF) with shorter regeneration
selective reduction system that adds aqueous urea to exhaust, and a NOx storage system for exhaust gas purification
20 percent better fuel efficiency than Mazda's 2.2 MZR-CD
Y4 4 cylinder Diesel Engines
Mazda Y4 engine (called 1.4 MZ-CD or 1.4 CiTD) is a rebadged PSA DV4 engine, produced in the PSA engine plant in Trémery or Ford's engine plant in Dagenham. These 1399 cc SOHC 8-valve turbo diesel engines with bore 73.7 mm (2.9 in), stroke 82 mm (3.2 in) and compression ratio 18.0:1 were shipped to Valencia (now in the Mazda 2 DE to Hiroshima or Hofu plants) and mounted into Mazda 2 DY and Mazda 2 DE together with a 5-speed manual transmission. The engine's maximum power is 50 kW (68 PS; 67 hp) at 4,000 rpm, maximum torque 160 N·m (120 lb·ft) Nm at 1,750 rpm.
Engine features:
SOHC belt-driven
aluminium cylinder block with cast iron liners
dual-mass flywheel
drive by wire accelerator pedal
VNT turbocharger, without intercooling
Euro Stage III emission rating (Euro Stage IV with DPF system, catalytic additive in separate 1.8 L tank, refreshed every 60,000 km)
Y6 4 cylinder Diesel Engines
Mazda Y6 engine (called 1.6 MZ-CD or 1.6 CiTD) is a rebadged PSA DV6 engine, produced in the PSA engine plant in Trémery or the Ford engine plant in Dagenham. These 1560 cc DOHC 16-valve turbo diesel engines with bore 75.0 mm (3.0 in), stroke 88.3 mm (3.5 in), and compression ratio of 18.3:1 are shipped to Hiroshima and mounted into the Mazda 3 (Axela) and Mazda 2 DE in three versions together with a 5-speed manual (Getrag-Ford developed, J65M-R) or 4-speed automatic "Activematic" transmission:
66 kW (90 PS; 89 hp) at 4,000 rpm, 215 N·m (159 lb·ft) Nm at 1,750 rpm
66 kW (90 PS; 89 hp) at 4,000 rpm, 205 N·m (151 lb·ft) Nm at 2,000 rpm mounted in Mazda 2 DE
81 kW (110 PS; 109 hp) at 4,000 rpm, 240 N·m (180 lb·ft) Nm at 1,750 rpm
Engine features:
DOHC belt-driven
dual-mass flywheel
second generation Bosch common rail injection system with pilot injection phase and 1600 bar pressure
6-hole injectors
Bosch EDC16 powertrain control module
Garrett GT15 (VNT15) turbocharger
large front mount intercooler (larger than 2.0 MZR-CD)
Return to Mazda R Diesel 4 Cylnder Engine
