ECUs, ODBII DTCs and PIDs
vz v6 cranks over no start code P0513
Discuss Diagnostic Trouble Codes and Parameter IDs for the Holden VY and VZ Commodores, Pontiac GTO, Vauxhall Monaro, and Chevrolet Lumina Models
Postby doubledip » Thu Jul 25, 2013 11:47 pm
car cranks over so not key or key reader
if you use the wrong code it fails.. wont succeed when programming
the code it is showing is that the ecu/PIM don't have the same matching immobiliser code stored in each other... sounding like the ECU maybe at fault if it is the only thing not replaced/programmed
Postby silversv6 » Fri Jul 26, 2013 12:36 am
Your right, it does crank.
I was just thinking they may have tried the code from the donor car BCM & not the car fitted to, (but was done by holden so they would know) but as you said programming will fail. sounds like PIM not matched to ECU properly or as you said ECU screwed. Be interesting to see the outcome. cheers
Postby TazzI » Sat Jul 27, 2013 1:40 pm
silversv6 wrote:If the PIM has been replaced it must be reset in the original car before fitting into another car. The PIM can only be reset 8 times maximum as well
huh... learn something new everyday.
silversv6 wrote:Sounds like the key or key reader may not be working.
Id agree with you on that, apart from the key is being registered as valid to turn the security light off in the cluster so the bcm is accepting it.
Id say redoing the bcm relink would be the go. Or turning VATS off to see if that sorts it.
Postby silversv6 » Sat Jul 27, 2013 2:51 pm
Well I was thinking, maybe correct BCM code may turn off security dash light & allow it to turn over & the PIM may just cut off injectors &/or fuel pump. We still do not know if it has spark or not....which may help a bit more.
But i'm only a dumbie, so let me know if I am wrong! Cheers
Return to ECUs, ODBII DTCs and PIDs
