I have a VX Commodore series 2 Acclaim.
The "TRACT OFF" light not working.
I believe with ignition on these lights momentarily illuminate to check if they are working but this light is not coming on.
I had it checked by mechanic with Tech Tool 2 and advised no issues at all. So I have removed cluster and checked globes replacing only blown globes but still not working. I have also checked with "Diagnostic Mode" (Mode and Right Button Before Starting) then press mode button until reach test for lamps and and gauges. I noted several lights not working including "TRAC OFF".
Is there something else to check or may be something faulty with the dash cluster and maybe needs replacing.
Any Advise would be much appreciated.
Cheers.
Mark.
