Peter7 wrote:Robertau wrote:Can the delay of the headlights be changed? like ign off lights off not the timed setting?
Rob
Yes, you can as I remember. With IDS/VCM2 from module programming, then personalize settings or exterior light -don't remember exactly.
Knew it could be done with VCM2 and IDS, i was hoping to be able to do it in terminal with my elm as i dont have a VCM2 yet, sounds like its on the cards though.
Tazzi, did you have a PCM/ECU hooked up on the bench What wires are used my studying says its all in EEC B connector
pins VPWR B34, B46 to 12V "switched"
KAPWR B40 toc 12v,
B10 case gnd, B01, B11,12,23 PWR GND all to ground
is there any I'm missing to power it up
hopefully have something hooked up on the bench soon myself just waiting on plugs>
I have found a program that can apparently do pats (I'm assuming with a elm), the only thing required is a extended license will report back with more info after i have had a play.
