Can anyone guess what happens when you forget to put the voltage regulator down from 14v to 5v?
This was going to be inserted inside the headunit... but... its a tad cooked now.
TazzI wrote:Can anyone guess what happens when you forget to put the voltage regulator down from 14v to 5v?
Robertau wrote:lets see howe i go here
os this box will plug into my icc with the square plug, the satnav;'s square plug will plug in to the box the reverswe camera plus in toi the box and all is good.
tha satnav always works untill im in reverse? and then tere is still a aux input or what?
ROb
TazzI wrote:loL. looking good!.
The wiring with the white heat shrink. Did you do that or ASL?
GoFastBits wrote:No i did that, thats where the last owner of the box destroyed the plug (both sides, not really sure how he did it tbh), left me with little option other than to direct solder it to the board to get it working again
