VE commodore electric window not working
Postby grant1962 » Thu Aug 30, 2012 9:39 pm
hi all Just wanted to share this info
I have an 07 ex police car, the window would not move, I pulled the switch box out and pulled it apart, very tricky job, springs and clips etc fell out. i found that coffee had been spilt in it and the switch contacts were covered. i cleaned them and put it back together and now it works fine been working good for a year. must warn you that you have to be very careful, I pulled it apart by first placing it in an old babies bath so if a spring or contact fell out it would not be lost, also nearly lost a spring about 2mm in diameter and 5mm long, needed my magnifying glass's to see it. This website (zerone) has a good example of how to get the switch out. (didn't know about it at the time). I went a step further and pulled the switch apart as I thought it was stuffed anyway so no loss if I wreck it. I would rate it about an 8.5 out of 10 for difficulty.
grant1962
Postby ZerOne » Fri Aug 31, 2012 7:47 am
Yeah, the power window switch can be a real pain in the bottom to take apart.
When my switch stopped working, it was beginning to rain (heavily) and I couldn't get the window back up.
I stopped in an underground car park and waited for the rain to stop, and drove back home to see what I could do.
Shorting the window up line was the first thing, which luckily worked.
I then took the window switch gear apart (in a mad rush to try and get the thing sorted)...
BIG MISTAKE on my part, as I didn't realize how many little diddly bits were inside there.
I lost a couple of bits (I'm sure they are probably cat toys now), so I ended up buying new switches from Holden to get myself out of trouble.
I still have the old switches here, and I should take them apart, and take pictures for everyone, so as they can see what a pita these things are to deal with !
Cheers, and thanks for sharing your experience Grant :)
  • In total there are 138 users online :: 0 registered, 0 hidden and 138 guests (based on users active over the past 5 minutes)
  • Most users ever online was 1141 on Tue May 14, 2024 5:34 am
  • Users browsing this forum: No registered users and 138 guests
