Ford Technical Document Discussion
Upgrading Instrument Clusters for Ford AU Falcons
A pace to discuss the technical documents for Ford vehicles from around the world
Postby ZerOne » Thu Jun 16, 2011 5:07 pm
The following forum thread is for discussing the Accessing the Upgrading Instrument Clusters for Ford AU Falcons document, located in our Documents section.
Postby HellOnWheels » Tue Dec 11, 2012 8:16 am
Excellent post, very helpful and got me out of a bit of s*#t,...
The one thing thats still stuffing me up, is that the coloring of wires as stated in ur post are
different to whats on my car. About half are right, but all the ones that need to be moved are
different coloring,...
Should i just ignore it, and go by the pin number or try find the right colored wire,...
Any more input on this would be appreciated,..
Cheers;
HellOnWheels
Postby ZerOne » Tue Dec 11, 2012 8:54 am
Form memory, I think the wire colours changed from Series I to Series II. (I cant remember exactly).
And I think the doco is for Series I. (Its been a while since I played around with AU Falcons, so my memory is very hazy).
What Series Falcon do you have ?
I might be able to find out more information.
Cheers, and thank you for the positive feedback ;)
Postby HellOnWheels » Tue Dec 11, 2012 11:02 pm
Thanx for the quick reply;
I did think that may be the problem, they decided to change colors,...
Why they thought that would be a good idea, has got me stuffed,..
Any help u can give me to point me in the right direction, would be
hugely appreciated :D
The car is a 10/2000 ute
Tanx muchly
HOW
HellOnWheels
Postby HellOnWheels » Wed Dec 19, 2012 2:50 am
Can anyone help me out with the wire colour coding for AU2 ute istrument cluster,
I'm trying to make XR Tickford cluster work properly,...
Thanx
:evil:
HellOnWheels
Postby gruntly69 » Wed Dec 19, 2012 4:36 pm
Hopefully this helps...
gruntly69
Postby HellOnWheels » Tue Jan 08, 2013 5:36 pm
Thanx alot for that Gruntly69, its helped heaps.
Also sorry for delay in response, some absolute Fu*ktard decided to help themselves to my computer and a few other things while i was at work :twisted: ,...
If possible, would u be able to tell me where u got that info from coz there's a few other things that i need to check up on, and i cant find it anywhere
Thanx
HoW
HellOnWheels
Postby gruntly69 » Thu Jan 10, 2013 5:12 pm
Glad it helped ;)
I'm not sure if I or the forum can get in trouble if I mention where I got it from, but if you go to your local aftermarket car parts supplier, they should have a few different 1's but there does seem to be a clearer 1 made by a certain R company!
Good luck, let me know if you want to look at anything else!
gruntly69
Postby HellOnWheels » Fri Jan 11, 2013 2:51 am
Thanx mate,
U've narrowed the field for me, time to fire up Mr. Google one last time,...
Ta heaps
HoW
HellOnWheels
Postby joshadams145 » Wed Mar 06, 2013 6:34 am
Hey, How did you go with upgrading your cluster mate?
Im trying to install a 2000 Series 2 Fairmont cluster in my 2000 Series 2 Forte 5 Speed.
I got stuck at the wiring but this looks like it will help alot, If all goes well for me I might write my own How to for this for S2/3 AU's.
joshadams145
Return to Ford Technical Document Discussion
