Need help asap car won't start after head unit swap
Postby velj » Thu Mar 07, 2013 5:46 pm
Hey guys put a Calais headunit in and now car won't start any ideas?
velj
Postby jezzab » Thu Mar 07, 2013 5:52 pm
What model car?
Postby velj » Thu Mar 07, 2013 6:02 pm
Sv6 ve 2007
velj
Postby doubledip » Thu Mar 07, 2013 6:08 pm
does radio work?
and what do you mean by not start (doesnt crank or cranks and doest fire)
Postby velj » Thu Mar 07, 2013 6:13 pm
Radio works, all accessories work, lights everything but when u go to turn the key nothing cranks over doesn't even try to, but the volt meter says it has 12v
If anyone has any idea and are able to call me my number is 0448055996
I'm stressing out like wtf!
velj
Postby velj » Thu Mar 07, 2013 6:14 pm
Would it matter if the outside temp says its 15?
velj
Postby velj » Thu Mar 07, 2013 6:38 pm
Now abs light comes on
velj
Postby doubledip » Thu Mar 07, 2013 6:42 pm
checked fuses?
havent blown one?
3 places to check.. under bonnet... pass foot well and boot or behind pass seat if ute
immobiliser fuse? small 2amp fuse in footwell
Postby velj » Thu Mar 07, 2013 6:47 pm
Where in the foot well? Checks all fuses in engine bay an boot
velj
Postby doubledip » Thu Mar 07, 2013 6:50 pm
passenger footwell there is a cover on the left kick panel
