Error code timing chain
Postby Jessiegirl » Sun Jan 26, 2020 3:56 pm
Hi all. I have a error code on my VE 2010 Holden commodore.
The Error code came up 2 years ago because the timing chain was out / just slightly
I had the car re programmed which cleared the code for around 12mths. The error code come
Back on, I was going to take it back to get re programmed but was told you can only do this once as it want fix it a second time, the code want clear error code again.
Does anyone know if this so true ?
Or am I just wasting my money taking it too Holden ?
Thanks
Jessiegirl
  • Most users ever online was 833 on Mon May 04, 2020 12:03 pm
