Specifications
Type 90 degree OHV 6.0L V8
Displacement 5967cc
Compression ratio 10.4:1
Valve configuration Push rods; one valve per cylinder
Assembly site Silao , Mexico
Valve lifters Roller lifters
Firing order 1 – 8 – 7 – 2 – 6 – 5 – 4 – 3
Bore x stroke 101.6mm x 92.0mm
Fuel system Sequential fuel injection
Peak power (ECE) 270kW @ 5700rpm
Peak torque (ECE) 530Nm @ 4400rpm
Materials
Block Cast aluminium with cast in place iron bore liners
Cylinder head Cast aluminium
Intake manifold Multi piece welded composite
Exhaust manifold Nodular cast iron
Pistons Cast aluminium alloy
Crankshaft Cast nodular iron
Camshaft Billet steel
Connecting rods Forged powdered metal
