Gen IV L98 6.0L Workshop
L98 Specifications
Discuss the Gen IV L98 6.0L (Non AFM) V8s
Postby ZerOne » Tue Dec 28, 2010 5:07 pm
Specifications
Type 90 degree OHV 6.0L V8
Displacement 5967cc
Compression ratio 10.4:1
Valve configuration Push rods; one valve per cylinder
Assembly site Silao , Mexico
Valve lifters Roller lifters
Firing order 1 – 8 – 7 – 2 – 6 – 5 – 4 – 3
Bore x stroke 101.6mm x 92.0mm
Fuel system Sequential fuel injection
Peak power (ECE) 270kW @ 5700rpm
Peak torque (ECE) 530Nm @ 4400rpm
Materials
Block Cast aluminium with cast in place iron bore liners
Cylinder head Cast aluminium
Intake manifold Multi piece welded composite
Exhaust manifold Nodular cast iron
Pistons Cast aluminium alloy
Crankshaft Cast nodular iron
Camshaft Billet steel
Connecting rods Forged powdered metal
Postby HenryZ1 » Mon Apr 21, 2014 8:32 am
Is anyone experiencing tappet [lifter] problems. This in only when the engine is cold.
Once warmed up it disappears. Engine oil has been changed.
What oil is the best
HenryZ1
Return to Gen IV L98 6.0L Workshop
