Hello all,
I own a Opel Astra 2005, and I was wondering if those Arb Id's are same for it too? I think it must have the same SWCAN line?
jezzab wrote:Sounds great Jason. Im pretty damn sure I have an NXP one of those boards kicking around. Might have to test it out
jezzab wrote:I've used the Sparkfun CANBus shield with my Arduino and had no problems at all
foxdie wrote:Oh and how you connected it? Directly to the bus or via the OBD-II port?
Just had a suspicion that pin 1 will only allow read-only access to the bus.
foxdie wrote:jezzab wrote:I've used the Sparkfun CANBus shield with my Arduino and had no problems at all
Just to be crystal clear, you've been able to send packets successfully?
Can you outline exactly how you've modified your shield to get it to connect and send? Any termination modifications etc?
jezzab wrote:Connected to the OBDII port. Can Hi tied to can low. I can send make chimes, do door locks etc. I can even change the startup logo on the radio with a couple of packets. But that's another story altogether :p
jezzab wrote:I made a few little apps that did little things like make the door locks go up and down with the steering wheel scroll wheel. One that reads the outside temp and displays it on the DIC on the instrument cluster. And a few more
