Postby advancedservers » Fri Nov 15, 2013 9:40 pm
I hope I'm on the right track!! (Forgot to say thanks to you Sorry!!)
advancedservers
Postby TazzI » Fri Nov 15, 2013 9:42 pm
advancedservers wrote:I hope I'm on the right track!! (Forgot to say thanks to you Sorry!!)
Did you end up posting your eeprom dump? The more the marrier. 8-)
Postby advancedservers » Fri Nov 15, 2013 9:44 pm
Yes I posted my old omega head unit and the new ssv one.. Wouldn't mind a copy of the my9.5 if anyone has a dump.
advancedservers
Postby Morris70 » Sat Nov 16, 2013 11:13 am
Here is a stock, unmodified dump from my 2010 Calais HU
The reverse cam option is 2 bytes, but the HU also needs to be at V9 software for it to work.
Is your HU from a 2010 or 2007 SSV ?
Morris70
Has thanked: 5 times
Been thanked: 24 times
Postby advancedservers » Sat Nov 16, 2013 7:14 pm
Hi Morris, I believe it's from a 2010 ssv but it's uses the old location in the EEPROM.
advancedservers
Postby advancedservers » Sat Nov 16, 2013 7:15 pm
Can you check the software version from the service menu?
advancedservers
Postby doubledip » Sat Nov 16, 2013 7:39 pm
Track Up Disc Up service menu
Track Up Disc Down Road Test
Track Down Disc Up Firmware
all are with the power button down for 10secs then release pwr button
Postby advancedservers » Sat Nov 16, 2013 7:40 pm
Ok cool I'll check now
advancedservers
Postby advancedservers » Sat Nov 16, 2013 8:00 pm
Thanks doubledip
advancedservers
Postby advancedservers » Sat Nov 16, 2013 8:05 pm
So I'm at 5.22..... Which means I need a tech 2 to update the mcu?
advancedservers
