LNF 2.0 Litre VVT DI Turbo Ecotech 4 Cylinder Powerplant
LNF Specifications
Discuss the 2.0 Litre VVT Direct Injection Turbo Ecotech Inline 4 Cylinder Engine from GM
Postby ZerOne » Mon Nov 22, 2010 7:40 am
2010 Ecotec 2.0L I-4 VVT DI Turbo ( LNF ) 06/05/2009
Type: 2.0L I-4 Turbo
Displacement: 1998 cc ( 122 ci )
Engine Orientation: L ( longitudinal ) T ( transverse ) L
Compression ratio: 9.2:1
valves per cylinder: 4
Assembly site: Spring Hill, Tennesee
Valve lifters: Hydraulic roller finger follower
Firing order: 1-3-4-2
Bore x stroke: 86.00 x 86.00
Fuel system: Direct Injection
Fuel Type: Premium recommended, not required
Applications: Horsepower: hp ( kw )
Chevrolet Cobalt SS ( Manual transmission ) 260 hp ( 194 kW ) @ 5300 rpm SAE CERTIFIED
Chevrolet HHR SS ( Automatic transmission ) 250 hp ( 186 kW ) @ 5900 rpm SAE CERTIFIED
Chevrolet HHR SS ( Manual transmission ) 260 hp ( 194 kW ) @ 5300 rpm SAE CERTIFIED
Chevrolet Cobalt SS ( Manual transmission ) 260 lb-ft ( 353 Nm ) @ 2000 rpm SAE CERTIFIED
Chevrolet HHR SS ( Automatic transmission ) 222 lb-ft ( 301 Nm ) @ 1650 rpm SAE CERTIFIED
Chevrolet HHR SS ( Manual transmission ) 260 lb-ft ( 353 Nm ) @ 2000 rpm SAE CERTIFIED
Maximum Engine Speed: 6350 rpm ( forward gears )
Emissions controls: Three-way catalyst, Positive Crankcase Ventilation, Evaporative System
MATERIALS
Block: 319 Aluminum
Cylinder head: Semi-permanent-mold 356 Al cylinder head
Intake manifold: Aluminum
Exhaust manifold: Cast stainless steel
Crankshaft: Forged steel
Camshaft: Cast nodular iron
Connecting rods: Forged steel
Additional features:
DI ( direct injection )
Dual-scroll turbocharger
Dual CVCP ( continuously variable cam phasing )
Sodium-filled Iconel exhaust valves
Cast pistons with oil squirters
Forged connecting rods
Steel crankshaft
Variable pressure fuel rail ( 50-150 bar )
Stronger block bulkhead and deeper water jacket
Coil-on-plug ignition
Direct injection high-pressure multi hole injectors
58x engine position sensing
Stainless steel fuel system components
FWD applications have dual converter system
Cam driven high pressure fuel pump
Return to LNF 2.0 Litre VVT DI Turbo Ecotech 4 Cylinder Powerplant
