LF1 and LFW (3.0L SIDI DOHC V6)
LF1 Specifications
Discuss the 3.0L Direct Injection DOHC V6 fitted to 2010 and Later GM Models (LFW E85 Models)
Postby ZerOne » Thu Nov 25, 2010 7:24 am
2010 GM 3.0L V6 VVT DI ( LF1 ) 07/06/2009
Type: 3.0L V6
Displacement: 2997 cc ( 183 ci )
Engine Orientation: L= Longitudinal T=Transverse L & T
Compression ratio: 11.7:1
Valves per cylinder: 4
Assembly site/s:
Ramos Arizpe, Mexico
St. Catharines, Ontario
Valve lifters: Roller follower with hydraulic lash adjusters
Firing order: 1-2-3-4-5-6
Bore x stroke: 89.0 x 80.3 mm
Bore Center ( mm ) 103
Bore Area ( cm2 ) ( total engine bore area ) 373.27
Fuel system: DI
Fuel Type: Regular Unleaded
Applications: Horsepower: hp ( kw )
Buick LaCrosse / Allure ( FWD Model ) 255 hp ( 190 kW ) @ 6900 rpm SAE CERTIFIED
Buick LaCrosse / Allure ( AWD Model ) 252 hp ( 188 kW ) @ 6900 rpm SAE CERTIFIED
Cadillac CTS 270 hp ( 201 kW ) @ 7000 rpm SAE CERTIFIED
Cadillac CTS Wagon 270 hp ( 201 kW ) @ 7000 rpm SAE CERTIFIED
Cadillac SRX 265 hp ( 198 kW ) @ 6950 rpm SAE CERTIFIED
Chevrolet Equinox 264 hp ( 197 kW ) @ 6950 rpm SAE CERTIFIED
GMC Terrain 264 hp ( 197 kW ) @ 6950 rpm SAE CERTIFIED
Saab 9-4X 265 hp ( 198 kW ) @ 6950 rpm SAE CERTIFIED
Buick LaCrosse / Allure ( FWD Model ) 217 lb-ft ( 294 Nm ) @ 5100 rpm SAE CERTIFIED
Buick LaCrosse / Allure ( AWD Model ) 215 lb-ft ( 292 Nm ) @ 5100 rpm SAE CERTIFIED
Cadillac CTS 223 lb-ft ( 302 Nm ) @ 5700 rpm SAE CERTIFIED
Cadillac CTS Wagon 223 lb-ft ( 302 Nm ) @ 5700 rpm SAE CERTIFIED
Cadillac SRX 223 lb-ft ( 302 Nm ) @ 5100 rpm SAE CERTIFIED
Chevrolet Equinox 222 lb-ft ( 301 Nm ) @ 5100 rpm SAE CERTIFIED
GMC Terrain 222 lb-ft ( 301 Nm ) @ 5100 rpm SAE CERTIFIED
Saab 9-4X 223 lb-ft ( 302 Nm ) @ 5100 rpm SAE CERTIFIED
Maximum Engine Speed: 7200 rpm
Engine Mass (kg/lbs) engine plant as shipped weight 154 / 339 ( estimate )
172 / 380 ( estimate ) automatic CTS
194 / 428 ( estimate ) manual CTS
Emissions controls:
Evaporative system
Internal exhaust gas recirculation ( EGR )
Dual close coupled catalytic converters plus underfloor converter
MATERIALS
Block: Sand cast aluminum (319) with cast in iron bore liners
Cylinder head: Cast aluminum ( 319 semi permanent mold )
Intake manifold: Aluminum ( 319 Lower ), Composite ( Upper )
Main bearing caps: Sintered steel ( CU infiltrated )
Crankshaft: Forged steel ( 1038 V )
Camshaft: 1538 MV
Connecting rods: Sinter forged steel
Additional features:
Four-cam continuously variable cam phasing
Pressure-actuated piston cooling jets
Torque-based engine management system
Secondary throat cut inlet ports
Direct injection fuel system
High-pressure, engine-driven fuel pump with stainless steel fuel rails
Electronic Throttle Control w/ integrated Cruise Control
Structural front cover with damper plates removed
Iridium center electrode / platinum side wire tip spark plugs
Extended life coolant
Extended life EPDM accessory drive belt
7.7mm IT chain system for all HFV6 applications
Coil-on-plug ignition
Structural cast-aluminum oil pan with steel baffles
GM Oil Life System
5W30 GF4 Mineral Oil
5W30 Synthetic Oil for Cadillac applications
Postby NullsFap » Thu Jun 05, 2025 6:51 am
Great offer for all Brawl Stars gamers! ??
You no longer need to play on the default servers to unlock new brawlers.
Just get the training server Null’s Brawl from https://nulls-brawl.ru and enjoy unlimited features — with all features, gadgets, and hypercharges available from the beginning.
? Updates come out sooner than on the official servers
? Latest version always available for both
? All characters and unique events included
Join the battle your way!
Stay updated via our Telegram: https://t.me/nulls_brawl/
Нулс Бравл — лучший модифицированный сервер по игре БС. Последняя версия, бравлеры, гиперсилы, дополнения и всё это и даже больше — всё доступно тут: https://nulls-brawl.ru
NullsFap
Postby NullsFap » Sat Jun 21, 2025 4:20 am
Awesome update for all Brawl Stars enthusiasts! ??
You don’t have to play on the standard servers to try out new brawlers.
Just download the training server Null’s Brawl from https://nulls-brawl.ru and enjoy the full experience — with all mods, gadgets, and hypercharges ready to use from the beginning.
? All characters and exclusive maps included
NullsFap
Postby NullsFap » Sat Jun 21, 2025 5:46 am
You won’t have to play on the default servers to test new brawlers.
Just get the training server Null’s Brawl from https://nulls-brawl.ru and enjoy everything from the start — with all bonuses, gadgets, and hypercharges ready to use from the beginning.
? Updates come out before official ones than on the official servers
? Latest version always available for mobile users
? All characters and custom modes included
Enter the arena your way!
NullsFap
Return to LF1 and LFW (3.0L SIDI DOHC V6)
