fg6e wrote:Plug 1 is the main cluster plug with the can-bus running through it. Dont think it's possible to run a MK2 cluster on a MK1. MK1 Clusters are part of the PATS immobiliser system. MK2 just needs central car configuration (AS Built Data) does not immobilise the car.
Is there anyway of adding can bus codes from a mk2 to a mk1 cluster
Ok, Didnt know that about the MK1 to MK2 clusters.
Strange they made such a drastic change.
Sooooo its back to solution one. Need a device that will send the required CAN data between HSCAN and MSCAN.
So main things will be:
- Send correct Media type to cluster (Aux, usb ect)
- Send correct commands to HIM
- Send correct dimming
